Stuff needed to make this turbo g35 happen!
+3
10Wrex
Skyline008
7 posters
please give me a list of things i need. thanks everyone
Skyline008- AWD Regular
Re: Stuff needed to make this turbo g35 happen!
A plan and a good shop. I know twin turbo set ups are readily available. I think its greddy who makes one for the G35, but im sure there's tons of other companies as well. The kits run like 6-7k if i remember right, but SHOULD have everything needed. Do some good ol google research as well as assistance from the forums here, and other ones and you should be good.
Im going single not twin
You'll need bigger fuel pump, bigger injectors, fmic w/ piping, blow off valve, the actual turbo with complete exhaust manifold all the way back, boost controller/solenoid, a tune, etc
might need a wastegate depending on what turbo you use, you will need to get the oil pan tapped, you will also need oil lines/vac lines and possibly coolant lines if its also a water cooled turbo
alloutEVO- EPAWD Frequent Flyer
Lots of beer and forum members to help!
Chaz2.5 wrote:Lots of beer and forum members to help!
Do you plan on buying a kit, or putting it together yourself?
Momentum Performance has an awesome GT35R kit for the G35, I would prefer that over something like a Greddy kit with 18g turbos that are older than I am... Turbonetics has a kit too I think they use a super 60 turbo I think..... not sure.
Operate_- AWD Noobie
