Challenge Accepted (WANTED's motor build)
Page 3 of 5 Previous  1, 2, 3, 4, 5  Next
Challenge Accepted (WANTED's motor build) - Page 3 Empty Re: Challenge Accepted (WANTED's motor build)
Post by WANTED on Wed May 15, 2013 6:10 pm
I never knew about the 03 outlander pump before now. I noticed in looking up the part number for it it's also listed for the 4g69 on teh 2012 eclipse. Interesting.
Post by WANTED on Thu May 16, 2013 4:35 pm
So tuning is scheduled for next Friday. Life is about to get very interesting very fast.
Post by evo my evo on Thu May 16, 2013 8:12 pm
Wow already!!! Ur fast ...it seems like u just started ur built a few Weeks ago
evo my evo
evo my evo
Post by WANTED on Thu May 16, 2013 8:42 pm
The 4g64 timing belt arrives tomorrow. I tried out the 4g63 one and didn't like how it fitted up. If it ends up being no real difference, I'll be sorely disappointed.
If you think about it, assembly does not take that long. I've actually been dragging ass and dicking around with parts that may or may not fit. Otherwise, it doesn't take longer than a day to assemble a motor.
Plus, it has actually been a rather long process with all the machine work that been going on since October.
Post by evo my evo on Fri May 17, 2013 9:16 am
I wasn't being sarcastic I guess time went by pretty fast
I was going with the 4g63 timing belt as well because people say it's stronger ..why is it that u didn't like and went for the 4g64 ..I though the only difference was going to be that the evo timing belt was going to be tight so u had and the 4g64 was going to be a little bigger so on one u have to retard the timing and advance on the other belt
evo my evo
evo my evo
Post by WANTED on Fri May 17, 2013 7:43 pm
Sorry, it wasn't my intention to make it sound like you were being sarcastic.
As to the timing belt issue, I'm finding myself to be dramatically off on cam timing while trying to degree my cams, at least according to the cam card. An example is that my cam card is telling me I should be seeing my intake cam open at 7 degrees before TDC. Yet my cam lobe isn't making contact with the rocker until 50 degrees ADTC, which can't be right.
OEM, the timing belt between the evo 8 and the DOCH 4g64 are teh same strength. The 9 uses a kevlar one oem, so some people switch to that one. Otherwise, only kevlar aftermarket belts come in 153 tooth length. That being said, there are more than a few big power 4g64 swaps in DSMs, Evos, and 3g eclipses making plenty of power without issue using non kevlar belts.
Post by WANTED on Sat May 18, 2013 2:17 am
Screw it. I know for a fact the cams are not an issue. I've been running on them for over 4 years without issue. I'm going to re-install the belt and get the motor dropped back in by tomorrow.
Post by WANTED on Mon May 27, 2013 1:11 pm
Hmm, I thought I had updated this. Well anyways, tuning delayed to next weekend on account of a technical issue being sorted out.
Post by WANTED on Sat Jun 01, 2013 9:28 pm
Oh joy of joy. Having fun with the knock sensor. FML. No numbers yet until I get this sorted out and back on the dyno.
Post by STi2eNvy on Tue Jun 04, 2013 11:55 pm
What's it doing?
Post by WANTED on Wed Jun 05, 2013 4:47 pm
Throwing an absurd amount of knock according to the sensor, but not audibly. I'm reasonably certain I screwed up the knock sensor on account of my over-torquing it. Throw in a 2.4 swap, which are loud to begin with, add a balance shaft delete, add a lightwieght crank pulley and you have a recipe for making your knock sensor go insane.
Post by STi2eNvy on Wed Jun 05, 2013 5:32 pm
Ahh, makes sense
Post by WANTED on Thu Jun 06, 2013 3:42 pm
Sweet!!!! All of my parts showed up last night.
Post by WANTED on Thu Jun 06, 2013 4:21 pm
Now if only my truck parts show up, then it will make for a rather interesting weekend Smile
Post by WANTED on Thu Jul 11, 2013 8:34 pm
Late update, but I've been slacking.
Just to be safe I pulled my oil pan to make sure there was nothing mechanical causing the knock sensor to go off. I happened to in fact find that one of my oil squirters was making contact with the back of a piston. No real damage to anything except to the squirter, which remained intact. So I swapped it out and ensured it was bent enough this time.
Since I had it off, I decided to continue to mod the cursed oil pan yet again. Long overdue, but I finally "massaged" it so that it's easier to take off with the engine in the car and not fight me as much. Pics to follow soon of what I did.
Post by WANTED on Thu Jul 11, 2013 8:35 pm
And yes, I did mod the truck a bit, but that's for a different venue.
Post by WANTED on Fri Jul 12, 2013 10:37 am
The source of my knock. Ooops.
Challenge Accepted (WANTED's motor build) - Page 3 IMG_0009_zpsed66a46a
The modified pan
Challenge Accepted (WANTED's motor build) - Page 3 IMG_0003_zps190c1f2e
Challenge Accepted (WANTED's motor build) - Page 3 IMG_0002_zps09d2c11e
Slight mod to the oil pickup as well
Before
Challenge Accepted (WANTED's motor build) - Page 3 IMG_0004_zpse595edb3
After
Challenge Accepted (WANTED's motor build) - Page 3 IMG_0005_zps737adbad
Post by WANTED on Fri Jul 12, 2013 10:39 am
On the plus side, the pan finally comes on and off the car absolutely smoothly with the engine in the car and the transmission mated.
Post by WANTED on Mon Jul 22, 2013 6:09 pm
So I finally got my knock sensor swapped out. Not a fun job with the IM on the car. It's pretty much impossible to get a crescent wrench on it that way. Mitsu makes a special socket for it, but rather than spend an arm and a leg for a one time use tool I spent $6 and a half hour with teh air grinder to make what I needed. Not exactly pretty, but It got the job done with ease. Saturday, here we come.
Post by WANTED on Fri Jul 26, 2013 4:45 pm
All buttoned up and ready to load up for tomorrow's witchcraft session.
Post by WANTED on Sat Jul 27, 2013 9:06 pm
So who wants numbers? Twisted Evil
Post by Chaz2.5 on Sat Jul 27, 2013 9:42 pm
Like a mustache ride! Let's see em!
Challenge Accepted (WANTED's motor build) - Page 3 DSC_28922-111111
Post by WANTED on Tue Jul 30, 2013 6:24 pm
I've decided to withhold the results until my custom title is applied.
Post by Chaz2.5 on Tue Jul 30, 2013 7:55 pm
Horseshit!
Post by Evo_Joe on Tue Jul 30, 2013 11:25 pm
Wont be as high as mine... Or marios... Or jerry's... So who cares?
Just dicking with you... Let see that S*** already...
Www.evo-joesgarage.com
Evo_Joe
