Timing Belt Lower Idler Pulley
Post by Behemoth2008 on Mon Jul 15, 2013 8:19 pm
I believe I found the reason that my 2001 IMPREZA L refuses to start. I pulled the timing belt cover today and discovered that the lower timing belt idler pully has blown up completely. Does anyone know the subaru part number to this pulley by any chance or have an extra laying around Very Happy ? I found the part on subarugenuine parts but there are 4 options for the idler pulley. The one that I need is here:
http://www.carparts.com/details/Subaru/Impreza/GMB/Timing_Belt_Idler_Pulley/2001/W0133-1629640.html?TID=80000000CP&origin=pla&CP=1&CP_SRC=PPC&003=27372932&010=cpgmtibeidpu01subaruimpreza19932011gmbw0133-16296401004275&gclid=CMyVmN7rsrgCFap7QgodhRsA6A
If I just go to Garcia, do you think they'll know what I'm talking about? Embarassed
Behemoth2008
Behemoth2008
Re: Timing Belt Lower Idler Pulley
Post by Chaz2.5 on Mon Jul 15, 2013 10:13 pm
This?...
Idler pulley
Post by Chaz2.5 on Mon Jul 15, 2013 10:16 pm
I usually go to subarupartsforyou.com first before anywhere else cause they supply the part numbers and is easier to navigate
Post by Behemoth2008 on Mon Jul 15, 2013 10:17 pm
Yes! This makes me Very Happy
Behemoth2008
Behemoth2008
Post by Chaz2.5 on Mon Jul 15, 2013 10:20 pm
Sweet! Now you can source it for the best price.
Post by Behemoth2008 on Mon Jul 15, 2013 10:20 pm
I wonder if this is really the cause to all the headache... or if something else is horrible wrong secondary to the stripped bearing.
Behemoth2008
Behemoth2008
Post by Behemoth2008 on Mon Jul 15, 2013 10:22 pm
Haha I found a JDM one on ebay... moar gofast, right?
Behemoth2008
Behemoth2008
Post by Chaz2.5 on Mon Jul 15, 2013 10:23 pm
I think this is it. Hopefully the heads are ok but I bet this is the culprit. You said it turns but doesn't start. You have fuel and spark. My guess would be cam position sensor, compression, or timing belt.
Post by Chaz2.5 on Mon Jul 15, 2013 10:24 pm
Behemoth2008 wrote:Haha I found a JDM one on ebay... moar gofast, right?
HAHA! 10hp at a minimum.
Post by Behemoth2008 on Mon Jul 15, 2013 10:26 pm
The crazy thing is it's the cheapest haha we shall see...
Behemoth2008
Behemoth2008
Post by Chaz2.5 on Mon Jul 15, 2013 10:29 pm
So long as its the same # it should be fine I would imagine. Is it a legit Subaru part though?
Post by Chaz2.5 on Mon Jul 15, 2013 10:32 pm
Post by Behemoth2008 on Mon Jul 15, 2013 10:38 pm
Aw damn... quick to jump the gun.
Behemoth2008
Behemoth2008
Post by Behemoth2008 on Mon Jul 15, 2013 10:43 pm
The part numbers in the description of the NSK one match up, so it should be fine.
Behemoth2008
Behemoth2008
Post by Behemoth2008 on Mon Jul 15, 2013 10:46 pm
Should be here by Friday, if you wanna come by and hang/wrench.
Behemoth2008
Behemoth2008
Post by Chaz2.5 on Mon Jul 15, 2013 10:48 pm
Sounds like a plan.
