Challenge Accepted (WANTED's motor build)
Page 2 of 5
Page 2 of 5 • 1, 2, 3, 4, 5
Re: Challenge Accepted (WANTED's motor build)
Yes, I actually made progress today. Motor's out, transmission is boxed up, and old motor disassembly in progress.
Yeah, my machining is almost done, as is my transmission.
But on to some news that will probably break a few hearts, my clutch sold and my block and 2.3 rotating assembly are spoken for.
Still have a cylinder head up for grabs though.
Yay!!!!!! I got my boost control sorted out. Almost have all of my wiring done too.
Well look what Santa dropped off at my house today.
My fuel parts finally showed up. I actually started on the new setup.
Got the new fuel line setup sorted out. It actually all fit better than I hoped after revising my approach to how I ran them on my initial mock-up. I may play a bit more due to my OCD, but I'll wait to do that tomorrow.
My machinist is putting the final touches on my block. It's interesting the things you forget to think of until your machinist asks you, but that's why I use him. I love Rocky Mountain Machining and the witchcraft he performs to make your S*** perfect.
Been rather quiet, but I swear big things will start happening next weekend. Everything arrives by freight Thursday.
All delays aside, I guess it's time to get started and putting the demon back together and making witchcraft happen. I gotta say, my "chunk-o-S***" has come a long way since I picked up this gem back in post 1.
I happened to pick up this little gem after a little arm twisting.
Finishing homework, otherwise I'd be cranking away at the build. I should be all buttoned up and ready to tune before the end of the month. More to follow.
The lead technician hard at work.
Slowly coming together. The boy only works so fast, as this is his first time.
After a little finagling with the oil squirters, finally got the pistons all in.
White Italians and coffee are what keeps this project moving forward.
The head technician hard at work installing the Custom Aged 625 ARP studs.
A far better option than the Cometic
Night and day difference.
He struggled a bit on the first go around of 50 ft lbs, but he made it. 75 and 100 he needed an assist from yours truly.
Starting to look like an engine
More to come soon.
More to come soon.
What's yours waiting on? I waiting on a water pump to show up, but that won't stop me from degreeing the cams.
As you can see, it really doesn't take me long to move forward.
So 2.1? 2.4? 2.4lr? Just picked up a 4g64 myself and debating on sending it to map or trying it myself for a 2.4lr
evo my evo- EPAWD Frequent Flyer
Sweet!!!!!! As for what to go with, you're just going to have to commit to one and go for it. All are good builds, but all have their quirks. In my case, doing my 2.4 on the "cheap" still cost me approximately $1700 for the block alone sourcing all the parts myself and hiring out the machining work to a machinist I trust. None of this included the incidentals such as oil pump.
So ur sticking with the 100mm crank and 150mm rod? H beam or I beam?WANTED wrote:Sweet!!!!!! As for what to go with, you're just going to have to commit to one and go for it. All are good builds, but all have their quirks. In my case, doing my 2.4 on the "cheap" still cost me approximately $1700 for the block alone sourcing all the parts myself and hiring out the machining work to a machinist I trust. None of this included the incidentals such as oil pump.
Steel I beam
Nice!!! The only problem I have with mine is where to make the hole on the block for the mivecWANTED wrote:Steel I beam
There's only one place to make it, and that's in the same location it would be on a stock 9 block.
That, and i read about a need to modify the MIVEC gear in that particular swap.
No real progress at the moment. Going through a few timing belt shenanigans, and accidentally broke my dial caliper. Otherwise, just finishing up some of the piddly things here and there.
Here's how she sits for the time being.
And the transmission almost ready to be mated up. Just need to verify whether or not the shim the TOB or not before it get's mated up.
Wow so pretty =) I just need another $3k worth of bolt ons. I sold most of my old parts (Headers, uppipe, wastegate, etc) so that I could upgrade to bigger better stuff.
What kind of water pump did u get? Evo with spacer or 03 outlander
...which oil pan is that
I'm using a modified evo 8 pump. I'm really not a fan of the adapter plates.
As to the pan, it's a modified AMS wet sump pan. Truthfully, down't waste your money on one. Buschur's modified stock pan works better. That AMS pan has been a royal pain in my ass since I bought it upon initial release.
» Resurrection!
» 2009 WRX Build
» 2009 WRX Build
Page 2 of 5
